03-12-2007 04:08 PM
03-14-2007 08:53 AM
Hi Zoe,
Did you put indicators on inputs to the ActiveX Container to see if any of them were Null? I assume you are starting with a very small program. Could you post a picture of it?
Have a good one.
03-15-2007 03:14 PM
03-16-2007 03:31 PM
Hi Toby,
If you wan't you can attach a snipet of your code or a picture. You can do this when you reply to a message and go to the attachment section of the post, and browse to the VI or image you want. I think that would be the easiest way to see what you are trying to do.
04-01-2007 11:21 AM
04-02-2007 01:20 PM
Hi Toby,
Can you check to see if the reference is NULL going into the _recordset property nodes, just to make sure the error is correct?
