07-13-2015 02:01 PM
Hi everyone, I'm trying to use a Parker 9630 motion controller in LabVIEW. I downloaded the library called "Labview Library" under "ComACRserver6.x" but I can't seem to get any motion from the 6 linear actuators that my setup utilizes. I have made sure the hardware is setup correctly, as I have complete control of all the actuators through ACR-View (software that comes with motion controller). I am getting an error when I run the SimpleExample.vi: -2147483638. Searching this error has come up with no luck. I was wondering if anyone could help me out with this!
07-13-2015 04:16 PM
You should contact the supplier, to see if they have an error code database that matches that error. You could also try attaching that Simple Example here along with the values that you are inputting to see if we can help there. If it's their example, usually it should work if you have it configured right. *I say "usually" because sometimes suppliers supply really crappy code that is shipped in non-working condition*
Chances are you've selected the wrong COM port or something?
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
07-14-2015 10:14 AM
Here are some screenshots of the vi I am working with and having trouble using
07-14-2015 11:38 AM
Please either share code by attaching the VIs, or by attaching Snippets.
That is an ugly, ugly example. Where does the error show up? Have you contacted the supplier about error codes yet?
Cheers
