ABS from MATLAB (simulink) to Labview (.vi file)
Hello
My Antiskid Control System project requires me to plot the graphs of wheel speed and vehicle speed. The original model is from Matlab simulink file-absbrake(this is an example of control)
I tried to convert the whole system into labview representation. I donot want to use SIT or RT or any other Labview tools. I wanted to convert from Simulink model into Labview element-by-element. Can anyone help me...plss
my due date for submission is 15march...so please help me
(4,889 Views)
this is another file for the simulink to be run
please change the file extension into '.m'
(4,885 Views)
pls change the file extension from '.vi' into '.m' to be run in matlab
this applies to absdata,runabs
for absbrake.vi, change '.vi' into '.mdl'
sorry, i have to do this bcoz the file extension '.m' and '.mdl' cant be attached
(4,884 Views)
abs.vi is the file that i attempted to 'convert' from matlab into labview
(4,882 Views)
syahrul,
Usually, if you have integrators or transfer functions in your model, you should use the LabVIEW Simulation Module. It also has a converter from mdl to LabVIEW that is pretty handy for this kind of operations. I was able to convert your model in 5 minutes (with some touches).
If you don't have that module (a lot of universities have this tool available for you, you just need to request), the advanced control VI could help, but you can only use Euler Integrator and I am not sure if this would work for your application.
Good luck!
Barp - Control and Simulation Group - National Instruments
Barp - Control, Simulation, RTT and HIL - National Instruments
(4,874 Views)
Hi.
I am fiding algorithm for ABS control system and I will be programming it with LabVIEW. Can anybody help solve it.
I have 2 week to report Help me
(3,460 Views)
