A .net constructor throws an exception. Assembly problem?
Hi!
I am new to this forum and LabView in general.
I am having a trouble with an .net constructor. I am calling a .DLL file with the Constructor Node. I get a "Error 1172....A .NET exception occured in an external assembly." I have installed the .DLL file to the GAC and I have verified in the View/.NET in Assemblies tool that the .DLL file is linked correctly.
My goal is to use a function called groupCommand() that I get from the SMBusAdapter constructor. What is interesting is that I have got other functions from the same .DLL file to work.
Can someone please give me some guidance. I attached the files I am using and there is also the GAC installer.
(I am running LabView 2011 on Windows Vista)
TIDP.SAA2.dll - the .dll file
group.vi - the file where the problem is.
send_byte.vi - A file where I got the .dll file to work with another function.
Thanks.
(2,102 Views)
A constructor should be called only once.
(2,084 Views)
Of course, but I am only calling the constructor once.
(2,082 Views)
