02-02-2015 05:37 PM
02-02-2015 05:45 PM
02-03-2015 08:54 AM
Hi Keira,
The commands I'm using are
FORM2;OUTPFORF;
With a little bit of manipulation, thiis gives you a 1D array of singles. You'll need to also find your Start, Stop freqs and number of points to come up with something really meaningful.
Just a suggestion - your time (and money) would be better spent upgrading your network analyzers. The new ones aren't that expensive and have an ethernet interface. The engineers can remote into the NA from their desks. The Keysight 5061B is about $27K and will run rings around the 8722.
Data collection vi for the 8753 attached. Use as an example.
Doug
02-16-2017 11:52 PM
I have a same question, lil difference is that: I am using VNA 8753E and I need to collect impedance for S11 and S22 parameters in Real and Imaginary part using a Lab View code in Time Domain.
I am using Antenna which works on Frequency 2.4Ghz.
Please help me out how to do the same.
Under is the lab view code I am using, of Agilent 8753 technology drivers.
I can measure the data in Time-Domain but cannot collect the real time data of the S11 and S22 parameters
