05-22-2015 08:02 AM - edited 05-22-2015 08:03 AM
Hai crossrulz,
Thanks for the quick example. But what I want to do was to give the user the freedom to control the 4 physical channel. Then the program would display the 4 signals from each channel signal in 4 seperate indicator where each signal enters the respective formula block. Here I got something I want to try out but I won't be able to do so until next Monday bcoz I don't have the hardware with me. Could u take a look at the code and comment if it would work or not? Perhaps you have another idea on how to do dis?
Newbie92
05-22-2015 08:05 AM - edited 05-22-2015 08:07 AM
Hi Newbie,
But I want to do was to give the user the freedom to control the 4 physical channel.
You still can do this while using just one DAQmx task for those 4 channels: apply different settings to each channel…
Then tthe program would display the 4 from each channel signal in 4 seperate indicator where each signal enters the respective formula block.
You still can do this while using just one DAQmx task for those 4 channels: use IndexArray on the result of DAQmxRead…
Edit:
- After looking at your edited image I recommend to stay away from ExpressVI functions. Use plain LabVIEW/G functions!
- You could apply scaling to each DAQmx channel so you would receive scaled values from DAQmxRead (for "simple" scaling functions)!
05-22-2015 08:36 AM
hai GerdW,
Thanks for the advice. Does it looks something like this? I don't have the tools to ensure it would run properly with my cDAQ rite now though.
Newbie92
