Don,
So the image that used to be in the subpanel on a page on the tab control moves when you change tabs and change back? Is that correct? I haven't heard of anything like that before. I wrote a small set of test code, but I wasn't able to get that behavior. Have you tried to unload the VI before switching the VI? To do this, copy the Insert VI node and then change the operation to Remove VI. Does this help?
Repost if you want more info!
Andy F.
