I am having a problem. I want to allow the user to control the background color and plot colors on the active-x 3D graph in labview 7.1.1. I am using the standard color box ctrls in labview to allow the user to pick, but the colors do not match. When I pick blue (0,0,255), it comes up red (255,0,0). When I choose yellow (255,255,0), it comes up cyan (0,255,255), and vice-versa. Black and white seems to work correctly, as well as green (0,255,0) being right in the middle. I am assuming this means whatever algorithm NI is using to create the color value is not the same from the labview side to the active-x control side. Anybody else run into this, and have a solution?
