3D Plotting. Crash Need help
We tried to plot our results in 3D, but the labview crashed.
The data is generated by matlab (x,y,z array.   1x102 double. Please see attachment)
Could someone help us, thank you.
Note.
1. Will NOT crash if we run labview in-built 3-d plotting example
2. Will crash if we run our one (see attachment) regardless which 3d ploting vi we used
3. Windows7, Labview 2015
(2,569 Views)
It is difficult to understand why you are having a problem (unless you really found a flaw in LabVIEW 2015).  To help us figure out what is going on, please attach:
  • the VI that you are using to plot the MatLab data (attach the VI directly);
  • the Matlab data (it's not clear if you have 3 1x102 arrays, or one 3x102 array ...)
If you have too many files to attach, put them in a folder, compress the folder, and attach the ZIP file.  Note that if you have multiple files in a Project, this is an excellent way to attach the entire Project.
(2,541 Views)
