05-18-2015 09:22 AM
I would like to generate a csv file from tables I filled in labview. I put an example of the csv file I want to get and the VI I tried to code. Can anyone help me to fix my VI to get the csv file in the right format?
Zied
Solved! Go to Solution.
05-18-2015 09:29 AM
If you want commas, then set the delimiters to be a comma. That is a simple input to the Write Spreadsheet File whose default is a tab.
