If the processing speed is not a concern you can do it with one loop by using shift reg and an insert array function. If you want to create the 1D array after your loops are done then you can do it as it is shown in the second loop. (but in this case Yamaeda's solution is more elegant)
Like I said before, if you have LabVIEW 2012 or later, you can configure those Autoindexing tunnels to be "Concatinating". A lot better than using more loops afterwards.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
