03-31-2015 01:04 PM
I have labview 2014 and a crio 9023. In the developer mode I can run the rt.exe and the developer mode web service that sits on the crio. Then I can have my pc app talk to the server. All three programs work together, but then I make a build......
Question 1
In the web services dialog I check my server, configure the ports, but then I need to look for the ssl certificate. Since I'm using labview's generated ssl cert on the crio, I enter the cio name/ip address to query the for the ssl certificate but none are found. Something I'm missing here? So I just enter the path in the box provided to the ssl certificate on the crio c:\ni-rt\system\niwebcer\server_certs\server_0.cer and proceed.
Question 2
I build and deploy. The crio is running indicated by the user led on the controller. I also put RT Debug String in my server startup application so that every 2 seconds the startup vi outputs the time of the last update from the rt.exe. So now I know my server is running. But this server does not show up in the web based - web server configuration page? Is the web server config page for standalone servers only or should I see my integrated server that is tied to my build?
Question 3
I change the webserver port that my pc app is directed to, and run the program. Unfortunately the server is not found. If I use the "show URL" button in the project, copy that url into explorer, I still get a server not found. Do the paths change for a build besides the port? Do I need to include my server method VI's in the build?
04-01-2015 04:34 PM
Got somewhere:
1. I leave that blank and let the crio use the "default" what ever that is. I can not get the the it to query and find the certificate. Couldn't resolve this question.
2. That page seems to be for standalone servers only. A unique server tied to the application does not appear here.
3. The ports I selected in the web services page of the build were already taken by the system/application web servers.
