12-07-2011 05:03 AM
12-07-2011 05:17 AM
you can not measure simultaneously 4W R and temp.
you will need to measure a voltage, convert it to a temp (check cold junction) then measure 4W (or the other way around)
N
12-07-2011 09:13 AM
12-07-2011 09:32 AM
The 2001 manual has SCPI commands exemples ( a lot).
You need to initiate the DMM
*RST
then configure it for 4W reading MEAS something, look in the doc
close the chanel ROUTe:CLOSe array
Trigger the measurement, etc
2001 is not the simplest instrument but it should work, just read then write something in LV and only then ask what is the problem...
N
02-05-2013 09:27 PM
I'm really newcomer labview user. Now I try to temperature measurement by 2001-TCSCAN with KE2000 DMM.
Could you tell me how to set up KE2000 DMM hard ware.
(I'm chemist. Please tell me how to set up 2001-TCSCAN in KE2000, and some parameter changing of KE2000.)
If it's permitted, could you upload vi file?
02-05-2013 10:28 PM
02-06-2013 03:26 AM
Thank you very much for your kind reply.
I cheked Find Instrument Drivers and try to use "KE2000 Getting started.vi".
It was working. But the thermocouple can connect only front side probe connector.
"KE2000 Getting started.vi" does not have Tc type selection setting.
Would you tell me which vi can control 2001 TCSCAN, multi Tc data logging?
02-06-2013 09:39 AM
The Getting Started is just that - an example that gives you a rough idea of what the driver can do. It is not intended to solve all problems.
My version of the driver does not have a Getting Started example so I don't know what you are using or if you grabbed an old driver for some reason. In my version of the driver there are functions to open/close relays of scanner cards that are inserted and there are thermcouple configure and thermocouple read functions. After you read the manual for the KE2000 and the TC card, you should be able to figure out what functions you need to call.
