04-29-2016 02:12 AM
Graph annotationa can be deleted on Front Panel using Data Operations --> Delete all annotations.
What about the similar operation in block diagram ?
And 2nd question: is it possible to modify annotation font and font size ?
Thanks.
Solved! Go to Solution.
04-29-2016 02:42 AM
Here is a solution that remove only one annotation:
05-02-2016 03:29 AM
HI Pavel,
unfortunately it is not possible to change the font or font size of the annotation text. Only the color.
With your example you only delete the name of the annotation and not the annotation itself. For that you can connect a constant to the property node "AnntList".
Best,
Anna
05-02-2016 05:24 AM
Ok, thanks Anna
