03-18-2011 04:53 PM
hello 🙂 i just want to ask a question...
Can i capture an image and save it using this vi?
03-21-2011 06:09 AM
Hi toufic,
yes it is possible, but you have to add this funcionality. You have to send a windows message to capture the image. I can show you an example later.
Mike
03-21-2011 12:50 PM
Thank u mike but it'll be better if u can show me the example as soon as possible..
Best regards 🙂
03-22-2011 01:44 PM
Hi toufic,
sorry for the delay. Please see the attached example. With the "get" button you send a signal to copy the current image into a picture control. Example02 is the main vi.
Hope it helps.
Mike
03-22-2011 02:52 PM
Thank u so much Mike for ur help I really appreciate:)
Best regards and Good luck!!
09-20-2011 05:21 AM
McArthur, THIS-IS-GREAT!
01-17-2012 06:23 PM
Hi Mike S81,
I saw many thanks replies on your example, but I cannot get it work. I've installed all native software for Logitech C170 web cam, but just getting black screen without any errors instead of video. Any ideas on that? May be I've missed some driver or....? I able to get video only via web cam's software, but not into LV.
There are no NI Vision dependable VI's installed on my PC
Alex
02-16-2012 04:39 AM
Hi Alex,
which OS do you use? Which LabVIEW version? Did you get any errors?
Mike
04-26-2012 10:27 AM
Very good program....Thanks alot..!!!!
07-11-2012 08:31 AM
Hi MikeS81,
When I run your VI - I see the webcam's image in the 2nd window (see the roll of tape in the attached JPEG), but only a green blank image in the first window. When I click 'get', it takes the picture of the green window. Do you know how to make the roll of tape stream be in the first window?
Thanks so much!
James
