Hello Robert,
From what I'm understanding you seem to have just installed LabVIEW 7.1 and are no longer able to load an application that you had running in LabVIEW 7.0.
What could be happening here is you may not have the installed the drivers for the DAQ device that you are using. I would recommend looking in the folder path C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib and make sure that you have folders in there called "Daq" and "DAQmx". If those folders do not exist, then download the latest version of the driver (
NI-DAQ Version 7.4 for Windows 2000/NT/XP) and make sure that you enable support for LabVIEW 7.1.
If the program you are running is a VI, then you might want to look inside the VI and see why there is the broken arrow as that would give you a better idea as to what is missing or broken.
