06-04-2015 09:44 AM
hello
im working on a project using mydaq.
i've connected 2 analog inputs , and tried to show both of the signals on graphs.
im using 'DAQ assistant' for each of the inputs.
but when i try to run , an error massage pops up saying "error - 50103 occurred at DAQmx Control"
is it possible to show two analog inputs ai0 ai1 at the same time?
if its possible how can i do it?
06-04-2015 09:51 AM
You have to have both channels in the same task. For you, this means you need to use a single DAQ Assistant that has both channels in it. You can split the channels after the data is read.
