@buckeyedave wrote:
Can the model be adapted to fit a superellipse?
A non-linear fit is a non-linear fit, so the answer is "Of course, but ...". Gauss (of curve-fitting fame) is reputed to have said (in German, almost certainly) "With 5 parameters, I can fit an elephant; with 6, I can make him wave his trunk" (I, myself, don't really believe Gauss said this, but it illustrates that if you add enough parameters, you can exactly fit almost anything).
Your model will have 6 parameters, and you are fitting 8 points, which may or may not be "well-placed" to allow a meaningful distinction between nearby choices of parameters (to say nothing about the possibility that there may be a little "noise" in the points, themselves). Have you ever heard of Sensitivity Analysis?
