08-18-2014 11:20 PM
For testing purpose I made *A50$ to *A0$ so all the time I need to read 4 bytes. I tought this will make some difference but here also Its failing. I will write and read * AA$ in same VI and will let you know.
Thanks a lot for your efforts gyus. Really greatful
08-18-2014 11:59 PM - edited 08-19-2014 12:00 AM
What? I thought you said you can't change the Arduino output format. This is really confusing especially without any information about your Arduino code.
08-19-2014 12:33 AM - edited 08-19-2014 12:37 AM
I am not at all changing arduino output format. This is resonse of output and I am just changing range of response I am getting from arduino. This is user defined. Somethinhg like testing sequence. Initially it was set to *A0$ to *A50$....here number of bytes are 4 and 5 so for worst case I was using 5. For crosschecking I changed upper response from *A50$ to *A0$ to make bytes to read as 4 in all the time
08-19-2014 01:51 AM
I am using a testsequence in which I am sending total 35 times including all the commnads.
I changed all the command with *AA$ and in which upperresponse as *A50$ after timeout error also 35 times it got passed. I tested total 7 times test passed. then I changed the upperresonse to *A0$ then also it got passed.
What you suggest now?
08-19-2014 02:11 AM
To be honest, I don't really know what you just said.
So, you changed all of the commands in your test sequence to "*AA$" and it worked without errors?
08-19-2014 02:13 AM
Yes command sent was *AA$ and response range upperresponse I changed *A0$ and *50$ and in both the cases it worked fine.
08-19-2014 02:16 AM
You see one test sequences have total 35 command response. i.e. total 35 times read and write. When once it got complete all 35 without error I say test passed.
Now I changes upperresponse *A0$ and *A50$. In later case I was getting timeout error becasue worst case byte need to read was 5 and actual 4. In both the ccases it was passed
08-19-2014 02:23 AM
I'm having a hard time understanding what you are saying but do you now understand what is going wrong?
08-19-2014 02:43 AM - edited 08-19-2014 02:45 AM
See I will explain now
Label | Command | Lower Response | Upper Response |
test | *AA$ | *A0$ | *A050$ |
Off | *S$ | *SOK$ |
This is my test sequence. For one test when all these read write passed then I say testing it passed. Now I tested in two condition one in which upperresponse is *A50$ and other in which *A0$. In both the case it passed. I run complete above test for both the cased i.e total 7 time all above command and it got passed
I have no idea what is going wrong?
08-19-2014 02:55 AM
Well, if that one particular command works, test a different one and see if there is a specific one that is breaking things.
