12-13-2014 01:11 AM - edited 12-13-2014 01:12 AM
HEllo everyone,
I am doing some work on array and Multicolumn Listbox, I want the hex array input should be displayed in a Multicolumn Listbox, and the total element in an array is 256, I want the 0-15 data from element of an array will be displayed in first row of Multicolumn Listbox , and on the second row 16-31 in second row of Multicolumn Listbox and so on, how to do that?
Solved! Go to Solution.
12-13-2014 02:15 AM
Here's a way to do that.
Marco
12-13-2014 02:38 AM
exactly MarcoMauri thanks you very much... very helful and it fits my satisfaction
12-13-2014 03:15 AM
my problem now is how to convert them in ascii , can you help me on it, thanks
12-13-2014 03:50 AM - edited 12-13-2014 03:54 AM
If you need to convert your U8 array to an ASCII string you can use "Byte Array To String" vi.
Marco
12-13-2014 04:19 AM - edited 12-13-2014 04:23 AM
thanks.. how about convert to ascii each value in every element of an array and display it to multiculomn listbox, so every cell in mlticulomn listbox has its corresponding ascii code with respect to the hex listbox ?
12-13-2014 06:51 AM - edited 12-13-2014 06:52 AM
Give this a try.
12-13-2014 08:14 AM
that was great crossrulz thank you very much for all the help...
