07-15-2010 08:53 AM
Hi
Does anyone have an example VI for file transfer using 1K XMODEM protocol
Michelle
07-16-2010 04:55 AM
You will probably need a third party tool to get this functionality in LabVIEW: http://digital.ni.com/public.nsf/allkb/765DB82497081D41862565370063E3A0?OpenDocument
07-16-2010 05:07 AM
Hi Rob
I have an XMODEM example VI, I guess I am going to have to rework it, only I did not want to reinvent the wheel if someone out there had a 1K XMODEM VI for file transfer already.
Thanks for the info thoe.
Michelle
01-04-2011 02:30 PM
Hi Michelle,
How did you solve this in the end? I found Xmodem_VISA.zip on
http://forums.openg.org/index.php?showtopic=258&hl=xmodem
But that needs to be rewritten for 1K Xmodem as well. And same like you: not that I can't, but if it has already been done...?
Best regards, Matthijs
01-05-2011 06:36 AM
Hi Guys
Original example reworked so enquirey now close
Michelle
01-05-2011 10:25 AM
Hi Michelle,
I am sorry but I don't understand your message. Is there a working 1K Xmodem example somewhere now?
Ifso, where?
thanks, Matthijs
04-15-2013 05:51 AM
excuse me I have LabVIEW 2011 and this exemple is made on labview 2012 and I can't open it 😞
I wonder if you can help me finding a solution for my problem 🙂
06-24-2014 01:41 AM
Any one has a XMODEM 1K file Transfer vi, if u have any idea on XMODEM 1K file Transfer please post the replay.
In my Project i want to transfer a 1K XMODEM file transfer through Serial Port.
06-24-2014 04:23 AM
Attached Xmodem VISA.zip is working under Labview 2010 (and probably higher).
You can use "Xmodem Send - VISA.vi" inside this library to send files.
06-24-2014 09:20 AM
In that library for 1K XMODEM file send 1K option was not there, that option is in Receiving XMODEM, but we need 1K option in send XMODEM.vi.
