limpid wrote:
> Thank you, Rob!<br>You mean I don't need to buy PCI-8252? What
> is it used for?
Well it is an IEEE-1394 interface but if your computer already has one
you don't need to install one from NI.
> What is the difference between PCI-8252 and PXI-8252? Are they both
> for PC?
PCI is a standard PCI plug in board. PXI is a bus electrically
compatible to PCI but with an entirely different mechanical form factor.
It is for special PXI chassis, a robust and ruggedized system mostly
used in industrial applications and test and measurement. As such it is
also a "bit" more expensive than normal PCs but can withstand extreme
manufacturing floor situations much easier.
> Do they have other I/O ports except IEEE 1394 port?
Well except that they have three IEEE-1394 ports, nothing that I could
see of!
Rolf Kalbermatter
