NI Home
Cart Cart | Help
You are here:
Reply
Peerformance
send bluetooth message from computer to NXT
is it possibel to send a message (string or number) form the computer to the NXT? I try a lot, but nothing works.
I’d like to run a program on the NXT and just send parameters by bluetooth (maybe motorspeed) by pushing a button on the LabVIEW-Frontpannel.
[I don’t like to run the program with “computer as target”]. Did somebody have experience with this?
RMathews
Re: send bluetooth message from computer to NXT
I dont have a NXT here at the moment, but LabVIEW you can find a Bluetooth pallette (Data communication>Protocols>Bluetooth)
So to read the values in your application you would have to use this VIs, but I am not sure if they are supported on NXT, that you have to test.
If they are not supported I dont think, that there will be a way to do this.
Xenox
Hey,
I found to examples which may help you:
Drive NXT using LabVIEW Front Panel
Send Data from Computer to NXT
Hope this will help you.
_____________________________________________________________________
---Please mark a post as a Solution if it solved your problem ---
