05-03-2014 05:44 PM
I have a pen plotter program that I've come back to. It works virtually. The Vi sends out: a Pen Up or Down number, an X axis number, and a Y axis number. These last two numbers are distances for lines that make up letters. I don't know if I have an up to date LabVIEW add on for NXT Direct Mode Programming.
My vi might work if I could use a couple of "Drive Distance Motors" in Direct Mode. Do they exist? Also, What is the limit on how big a vi can be? How many structures can one use ? Is memory the only consideration?
05-05-2014 10:24 AM
Hi dunnor,
A new version of the MINDSTORMS Module is available for download here: https://decibel.ni.com/content/docs/DOC-15615 .
What type of motor are you controlling? In the previous version of the MINDSTORMS NXT Module, the drive distance function for LEGO motors was available on the I/O>>Complete>>LEGO Motors pallette. The drive distance function for third party motors was available on the Third Party Motors palette. In the newer version, both share a drive distance function in the I/O>>Motors palette.
A direct mode program is one with a PC target. There is no limit for the size or number of structures in a direct mode program. A remote mode program is limited by the available memory on the brick.
- Gary
05-05-2014 06:18 PM
05-06-2014 08:43 AM
What version of the LabVIEW Module for LEGO MINDSTORMS are you using? You can find it in the Help menu.
05-07-2014 09:25 PM
I have LabVIEW 2009 student version 9.0. I don't know what version the NXT LavVIEW Add ON is. My nephew sometimes programs in the G software that came with our NXT Mindstorms Education Set. The LabVIEW Add On came from a CD that came with a LabVIEW NXT Textbook by Michael Gaspri (If I remember his name right?). I'm pretty sure I update once after I installed the CD software.
05-07-2014 09:34 PM
I went to Help and looked under About NXT Module, and it said, "NI LabVIEW 2009 NXT Module.
I sounds like an update might have what I'm looking for.
Thank you for your time
ND
05-08-2014 09:38 AM - edited 05-08-2014 09:41 AM
Yeah, I'm not sure how to drive a distance in the 2009 version. Sorry about that.
