NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
walter.fuehrer@htl-hl.ac.at
lego mindstorm nxt 2010 install error
Hi, I tried to install lego mindstorm nxt 2010 (LVLM2010) and got errors that some files are missing - see attached file. Please help and regards, Walter
Member
ESearl
Re: lego mindstorm nxt 2010 install error
The problem is that all of the filenames inside the LVLM2010 folder have been errantly capitalized. This prevents the installer from finding required files because the names are incorrect.
Where did you obtain the installer for LVLM? My guess is the filenames were probably changed by copying the media from some other file-system or OS.
-Ethan
Member
I installed it in vmware-fusion (LabVIEW 2011 was also successfully installed) and dowloaded it directly there. So it seems not to be a filesytem problem, does it? Walter
Member
Hi again.I did entpacking once more and tried to install it again. Now I got an error that LV2010 have to be installed before (LV2011 is already installed!) - see attached error message. So I Think that this package cannot be installed on LV2011. What do you mean? Walter
Member
ESearl
LabVIEW 2011 should not make a difference.
LVLM is actually a version of LabVIEW 2010 that includes the "NXT Module" for interacting with LEGO Mindstorms.The error you are seeing now occurs when someone tries to install the NXT Module without LabVIEW 2010 installed.
When you unpacked this time were the filenames still capitalized? Did you try and run the NXT Module separately because LabVIEW2010 won't install?
There will be a version of the NXT Module for LabVIEW 2011 available very soon.
-Ethan
Member
ESearl
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
