08-14-2008 07:45 AM
NI工程師你好,我是frddomcanopy
對於網路上的Labview and Nxt 有點看不懂,想直接請問妳們以下問題
1. Labview8.5連結Nxt介面是否需要某個軟體相連接嗎??
2. 是否可介紹怎樣寫入Nxt嗎??
謝謝
08-14-2008 09:24 AM
Hi freedomca,
can you write in english please? You can check the connection if you use the vi´s to search for a connected NXT.
Hope it helps.
Mike
09-18-2008 01:10 PM
Hello frddomcanopy,
You need to install LabVIEW NXT Toolkit so that you can work with NXT using LabVIEW. Once you get NXT Toolkit installed successfully, you can then launch the NXT terminal from LabVIEW menu bar Tools>>NXT Module>>NXT Termial. Using this terminal you will be able to send files to NXT.
-Nan
