LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
changing iteration count of a while/for loop
By default the for/ while loop iteration count will start from '0'. I want my loop to start with any other value say '10'.
Is it possible to change the value of loop count , so that it counts from '10' (in this case).
(6,509 Views)
There is no built in way to customize the behavior of the iterator, but you can perform any math you wish to it in your program. In this case just add 10 before you use the iterator.
(6,504 Views)
Thnx a lot 🙂
Bt I already know this method. I was looking for some other method if available.
And we can also do the same using shift registers. 🙂
Runjhun.
(6,499 Views)
