LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Ultrasonic Sensor
I have tested the Ultrasonic sensor using the brick and it works.  However, with the program I have written gibberish numbers appear such as 950 or 150.  I know I'm missing something but I don't know what.  I suspect it's something with the flatten to string like I'm not just flattening a number but the cm or in string value.  Thanks.
(6,317 Views)
I think the problem from using flatten to string so I replace it by number to decimal string.
the attatchment is your file but I use number to decimal string block. I hope that work.
(6,241 Views)
