04-12-2007 02:53 PM
04-14-2007 02:59 PM
02-22-2008 03:08 AM
hi.I need to know if I could save data using file access block within labviwe nxt toolkits,for example could I save sensor reading using these block(easy write block,easy read block..) plz I need to know as soon as you could and with details .
thanx
02-22-2008 06:53 AM
02-22-2008 01:04 PM
02-23-2008 03:36 AM
look I try use easy write block to save US sensor reading(distance)
then I use easy read block to display that reading but nothing appear on LCD and there was a warning:
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\addons\NXTToolkit\Library VIs\File Access\File_Read_Line.vi
- The shared library expected to be at "NXTInputOutput.dll" was loaded from "C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\addons\NXTToolkit\shared\NXTInputOutput\NXTInputOutput.dll".
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\addons\NXTToolkit\Library VIs\File Access\File_Resize.vi
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\addons\NXTToolkit\Library VIs\File Access\File_Write_Line.vi
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\addons\NXTToolkit\Library VIs\File Access\NXT_EasyWriteFile.vi
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\addons\NXTToolkit\Library VIs\File Access\NXT_OpenFileForRead.vi
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\addons\NXTToolkit\Library VIs\File Access\NXT_OpenFileForWrite.vi
what could be the problem???????????
I attache the program I wrote
