NI Home
Cart Cart | Help
You are here:
Reply
Alex_Petersen
Sample time? (read sonar halts)
I have a very simple program, that reads the distance from the Sonar-sensor. If the distance is above 20 cm, the motors A and B will turn backwards until the distance is above 20 cm.
This works just fine in debugging-mode, but not when the program is targeted to the NXT itself. I think this has to be something about sampletimes? I can add a Wait for 200 ms" and its get bettet. But there must be some kind of documentation about this?
Any thoughts is appriciated.
Regards, Alex.
A.Rohde
Re: Sample time? (read sonar halts)
Hi Alex
It should not be nessasary with a wait function.
Could you please check if the following example program works on your device:
Help --> Find examples --> Directory Structure --> NXT Robotics --> Motors --> Case_Structure_Motor_Control.vit
It has approximately the same structure as your application.
Best Regards,
Anders Rohde
Applications Engineer
National Instruments Denmark
Alex_Petersen
Hi Anders.
Thank you for your reply.
The example program works just fine. It could seems like the Read Sonar is different than the other Read sensor? I found another guy with the exact same problem:
http://stackoverflow.com/questions/8404029/why-does-this-program-work-in-labview-when-targeted-to-co...
Regards, Alex.
Alex_Petersen
Anyone?
A.Rohde
Hi Alex
What version of the NXT module are you running?
Alex_Petersen
I'm using LabVIEW 2011 with the LabVIEW NXT Module 2011.
Downloaded from:
http://joule.ni.com/nidu/cds/view/p/id/2637/lang/en
