05-22-2008 04:09 AM
I am having trouble with controlling the motor with the NXT toolkit...
The idea is that the motor gets the command to turn to a specific position, not
for a selected amount of degrees..
The motor is attached to a disk divided in 6 compartments. The input comes from
the Hitechnic color sensor, and depending on the color the disk should turn to
a specific compartment.. But I cant seem to get the reset motor block working,
maybe I am interpreting they way it operates wrong..
also, when on fairly high speeds, the motor isn’t very accurate.. since its a
servo with feedback, shouldn’t it be able to correct its position if it goes
too far?
05-22-2008 08:31 AM - edited 05-22-2008 08:33 AM
05-31-2008 07:54 PM
Bramgozer - I cannot help you, but can you tell me where to get the color sensor VI? The HiTechnic VIs do not compile-to-brick for me, being password protected.
The reference to "FTC demonstration competition" did not lead to anything.
You mentioned in a previous thread that you asked HiTechnic whether they support the color sensor in LabView -- any reply from them?
- nossr
06-01-2008 04:38 AM
06-01-2008 11:42 PM
Bramgozer - Thanks for the reply. I don't know what a PM is but you can forward the email you mentioned to roger.noss@sbcglobal.net
- nossr
06-11-2008 02:00 PM - edited 06-11-2008 02:01 PM
06-11-2008 03:55 PM
06-16-2008 02:38 PM
10-17-2008 05:27 PM
Sorry by my english ...
in fast movements when you turn off the motor they pass the position, I have one projet with the same problem and I correct this including one control in power motor, when the position is near the stop position I down the power level motor, but never "0" with 5 or 10 they stop correctly, if you wish can put more steps and down first to 25 and after to 10 with comparators or but one linear control to power=|endposition-position+1| * 10 and one comparator and if power > 75 then power = 75.
I hope that work.
Now, one deal, can you send the VI to hitechnic color sensor and other VI that you have to hitechnic ?
