It worked, thanks Mike.....
By the way do you know why each time i try to compile some code for the NTX this error shows up:
Error 1003 occurred at Invoke Node in NXTToolkit.CompileOrCancel.vi->NXTToolkit.TargetAgent.vi
Possible reason(s):
LabVIEW: The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Open the VI in LabVIEW using File>>Open and verify that it is runnable.
Method Name: Run VI
VI Path: C:\Archivos de programa\National Instruments\LabVIEW 8.5\vi.lib\addons\NXTToolkit\gcompiler\Backend.LEGO\NXT.Compiler.Core.vi
Thank you Mike, i use labview 8.5 and i have already mass compile everything
