LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
RS-485 Interface on Port 4
Today I've read on nxtasy.org that it's possible to send via RS485 on Port 4 Messages from one Brick to another.
Has anyone tried to make a VI or any Hints how to build it?
Or Is it possible to link two nxt-Brick with a Low-Speed read/write command?
Cheers, Olaf
(6,152 Views)
Hi!
I have the same problem... I connected two NXTs using the NBC compiler (http://nxtasy.org/?cat=-18&s=programmed): here it's easy to use HighSpeed functions...
But now I must translate the communication in Labview...
Any suggestion is important!!!;)
Laura
(5,821 Views)
