LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
NXT coding problem, tic & toc problems?
Hi guys, I'm trying to make a car that parks itself but I'm having a problem with the bit of code that the car uses to find the space, I think there's an issue with my while loop because the car doesn't stop once a big enough gap has been found after three seconds, could you please have a look at my code (we're in matlab by the way) and point out any problems.  Thanks!
while motorA == 1
    mB.Stop('brake'); % stop the turning motor so car drives straight
   if distance < 40 %distance needed on ultrasonic sensor to prak in
              tic;
             distance = GetUltrasonic(SENSOR_2); % re-set value of distance for next turn through loop
   end
   if toc > 3
      mA.Stop('brake'); % stop the driving motor
              motorA = 0; % break out of loop as gap has been found (while loop no longer satisfied
   end
end
(4,407 Views)
Hi.
The toc can't be used for comprison like you do with the toc < 3. That I believe would always return 0 and therefore the stop if-loop never runs.
The functionality might be preserved if the toc is loaded into another variable like TimeElapsed = toc.
This is stated in the documentation of the tic-toc: http://mathworks.com/help/matlab/ref/tic.html
For a more indepth reply you might want to seek out the help from the users/engineers at MATLAB. They are available from http://mathworks.com/matlabcentral/.
Best Regards,
Mette Bertelsen
Application Engineer
(4,381 Views)
