10-10-2015 04:14 AM
Hi guys, I'm trying to make a car that parks itself but I'm having a problem with the bit of code that the car uses to find the space, I think there's an issue with my while loop because the car doesn't stop once a big enough gap has been found after three seconds, could you please have a look at my code (we're in matlab by the way) and point out any problems. Thanks!
while motorA == 1
mB.Stop('brake'); % stop the turning motor so car drives straight
if distance < 40 %distance needed on ultrasonic sensor to prak in
tic;
distance = GetUltrasonic(SENSOR_2); % re-set value of distance for next turn through loop
end
if toc > 3
mA.Stop('brake'); % stop the driving motor
motorA = 0; % break out of loop as gap has been found (while loop no longer satisfied
end
end
10-12-2015 02:26 AM
Hi.
The toc can't be used for comprison like you do with the toc < 3. That I believe would always return 0 and therefore the stop if-loop never runs.
The functionality might be preserved if the toc is loaded into another variable like TimeElapsed = toc.
This is stated in the documentation of the tic-toc: http://mathworks.com/help/matlab/ref/tic.html
For a more indepth reply you might want to seek out the help from the users/engineers at MATLAB. They are available from http://mathworks.com/matlabcentral/.
Best Regards,
Mette Bertelsen
Application Engineer
