11-02-2011 04:08 AM
Hi Jolanta,
That sounds like a good idea. Good luck with your xy table build!
Yes please do post back when you have an update.
Kind Regards,
11-11-2011 11:33 AM - edited 11-11-2011 11:34 AM
Hello there
I have built assembly which moves my sensor in X-Y direction. I have attached the file which moves the sensor in front-back-left and right direction and acquires the corresponding voltage.
Now I am stuck how to get the 3D scan of an object beong scanned? That is how to get the X,Y and Z co-ordinates of the object being scanned in a dynamic manner.
11-11-2011 12:52 PM
Something like this might work. You will probably want to change the Daq call to be a single shot aquisition. Then the final output here would be a 2D array of z coordinates
11-14-2011 06:27 AM
I dont get the output. The array on the front panel remains unchanged.
11-15-2011 07:01 AM
hello there the array remain unchanged,
