05-08-2012 11:01 AM
i actualy do compete in ftc and il just put the samantha module on thank you
05-09-2012 04:10 PM
i have the samantha module but im having problems hetting connected to it can someone show me sep by step how to configuere it to the field control system
05-09-2012 04:21 PM
If you have the latest firmware on the Samantha as well as the latest version of the LabVIEW for Minstorms software, the Samantha looks like a WiFi adapter (instead of "USB" or "Bluetooth" for a connection type, you'll see "WiFi" when scanning for NXT devices). Samantha requires configuration, however, so that it knows what access point it is to connect with (along with WPA2 encryption keys if necessary). Check out these resources to help you get started:
Setting up the FCS: http://www.usfirst.org/roboticsprograms/ftc/fcs
Setting up Samantha: http://www.usfirst.org/roboticsprograms/ftc/samant
-Danny
05-21-2012 04:48 PM
Hello ;
can some one help me, my laptop cannot recognize my nxt robot, i installed the fantom driver but i have already the windows error 37i tried to plug it and play but nothing,
please if you fave an answer!!
05-23-2012 05:17 AM
Hi Chya,
What else have you installed? Are you looking for the device in the Measurement & Automation Explorer (MAX)? Or are you looking in the Windows device manager?
05-23-2012 10:44 AM
Hi Jeff;
i was llokin in the window device manager and there is an exclamation point in to the robot driver, i tried every thing but there is no sulotion;
have you some idea to help me??
05-25-2012 02:32 AM
Chya,
What else have you installed? You said you tried installing the Fantom driver. What else have you done?
09-13-2012 02:26 PM
A cause that LabVIEW does not recognize the NXT is loaded with the firmware because of ROBOLAB or Bobot C. What you need to do is reset the NXT. Removing the batteries and pressing the reset button is at the center in a small hole.
have a nice day!!
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
