08-08-2008 07:49 PM
Hi Liang,
Yes, I am using the english version. I did encounter similar problem as you did. The resulting log should be of help though it was not user friendly. Highlighting the log information and pasting them in word made examination easier. Of course you can save the log info to a file. I don't know if its luck but when I re-compiled prior errors did not crop up anymore. You can probably get targeted help from the forum if you indicate which component of the mass compilation resulted in error. You can even post the resulting compilation log as its not that huge a file.
Regards.
Epo
08-17-2008 06:11 PM
thank you very much, Epo, now I have installed LabVIEW 8.20, and all the Problems are solved. 🙂
Liang
