LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
LEGO NXT autonommus robot
Hi, I have LabView 2010 and the NXT module for labview 2010
I have  runnig a line follower robot whit a graphic interface (some XY graphic in the front pannel) programmed in Labview but when I unplug the USB cable my robot don´t work at all, so I guess the programm is being executed in the computer and just send some sort of commands to the robot, but I wanna make an autonomous robot, because you know, is a litle goofy going behind the robot whit my laptop, also I don´t have the Bluettooth dongle =(
Is there any way to :
1) Make your NXT code in Labview
2) Download the code to the NXT brick
3) Unplug the USB cable from the computer and from the NXT brick
4) Running the programm without a computer
I´m sure that it´s posibble and maybe this is a silly question but I can´t find the way to make it work by miself, Thanks for answer! =D
Best Regards
Diego
(9,692 Views)
Accepted by topic author HxcBarrigaHxc
Hi Diego,
You need to change the "Target" of your line follower program.
With your NXT brick plugged in, go to the File menu of your program and select "Target to NXT".
The bottom left corner of your window should turn orange to display the name of the NXT that you will target.
You can right click there to scan/switch nxts as well.
Once you target, you can use the run button to compile, download, and run your program.
-Ethan
(9,683 Views)
Thanks buddy, it´s working fine now
(9,669 Views)
This article is intended to control the direction and speed of a Lego NXT robot using the directional buttons on the computer keyboard, strategic control distance limited by the scope of the Bluetooth transmitter installed.
https://decibel.ni.com/content/docs/DOC-32462
(8,842 Views)
Hey, I was trying to do the same Thing but i get some Errors, when I´am trying to deploy the program. Is there a solution for the Problem?
@ESearl wrote:
Hi Diego,
-Ethan
(5,148 Views)
BenGernemann,
This thread had already had a solution selected and as a result has decreased visibility. I would recommend creating a new thread and posting your question there. You can link to this thread from the new thread to reference any pertinent information.
Also, I would recommend listing out the exact errors you are receiving on the new thread with a bit of context about when the errors occur to help those who look into your issue.
Casey G.
(5,137 Views)
