02-22-2008 06:31 PM
03-09-2008 11:39 AM
Hi
> 64 views and zero responses ... Have i asked improper questions ? or may be too many questions in one post ?
Were my questions, too vague or do they just require too much time to create a response ?
Is there another location/forum where i can ask questions concerning details about using Labview Toolkit and NXT regarding low level sensor interfaceing with I2C and RS485 ?
I really would like to learn how to implement the items i mentioned in the first post, and would like to find a place to ask for help.
KC
03-09-2008 06:21 PM
03-11-2008 08:30 PM
Hello lucasca
Thanks for takeing the time to answer.
I had not seen all of the links that you refer to, so i gained some good information.
I find it strange that the there is no possible way to develop a NXT G block to access the RS485.
I have tried the solutions with other languages, and they work, but i would like a NXT G block.
I already have implemented what i want using other languages for I2C, but again, i would like a NXT G block.
The mindstorm I2C blocks are the vi's that i have been trying to modify to implement the multi byte reads and writes.
And as you mentioned, it sure would be nice if someone expert in labview, could create a screencast showing how to develop and debug a NXT G block . And using the I2C multibyte interface as an example would be great 🙂
There must be a recomended process to go from concept to block diagrams to front panels to debugging to deploying on the NXT.
I have gone thru the pdf docs and followed the examples, but still must be missing an important step in the development process.
Because when i try to do something like low level I2C, i do not see a good way to debug or simulate execution.
Thanks again for the links, ill keep plugging away.
KC
03-13-2008 06:58 PM
04-05-2008 10:40 AM
