02-21-2011 02:00 PM
I'm trying to use LabVIEW to control an NXT rover. I found the follow a line VI in the NXT toolkit, but it appears to cause the rover to veer in one direction. This is making it so the rover will turn in one direction, but not the other direction. A quick search on the forum didn't turn up any hits. Can someone explain how to make the rover turn in other directions? Attached is the follow a line VI.
02-22-2011 09:58 AM
Hi cgates!
I'm not sure why your Rover is only going one direction. There are some good tutorials online that will help you get started. Try reading these articles....they should help you get started:
Hope this helps!
Starla T.
02-24-2011 12:00 PM
Thanks for the reply. I can't get the tutorial to download. Keep getting a a message that the URL is wrong. Can you post again?
02-25-2011 11:28 AM
Hi Cgates,
Try this one:
ftp://ftp.ni.com/evaluation/mindstorms/LabVIEW_Toolkit_for_LMS_NXT_Getting_Started_Guide.pdf
02-25-2011 02:30 PM
Are there any resources on the web for following a line with the NXT using Labview toolkit? I've found a lot of mention of labview, but not much in the way of actual examples. The built in line following doesn't seem to work well.
06-24-2011 12:01 AM
Has anyone got a VI to share so I can try…and learn from an actual working model please.
I want my LEGO robot to follow the black line on the circuit paper which came with the kit. I heard it is called 'Bang-Bang' control…is that correct? I have built the robot 🙂
Thank you in advance.
Michael
06-24-2011 06:30 PM
If you're using the NXT LabVIEW toolkit as well, the function you're looking for is called "Follow A Line." This can be found under NXT Robotics >> Behaviors >> Follow A Line. When you drag that function onto your block diagram, it should drop down some working code that you can take a look at. Let me know if that's not what you're looking for.
08-25-2011 11:49 PM
Thank you. This is helpful.
02-27-2014 06:57 AM
Hi Th0r; I have same problem like mvallance. I'm using Labview 2010 but I couldn't find this file (NXT Robotics >> Behaviors >> Follow A Line). Could you please send me the source file?
thank's a lot for your help...
02-27-2014 09:03 PM
You will find it under FILE - NEW NXT - Robot Project ..
and there is a Line Follower VI
