LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
File Error!
I am trying to program my NXT module using the LabVIEW NXT Toolkit.
I have exactly copied the volume waveform chart from Getting Started with the LabVIEW Toolkit for LEGO® MINDSTORMS® NXT: ftp://ftp.ni.com/evaluation/mindstorms/LabVIEW_Toolkit_for_LMS_NXT_Getting_Started_Guide.pdf
The NXT terminal connects to my NXT module fine, but when I download the program it appears in the NXT files as just .rxe (i.e not program.rxe, the name is completely missing). When I navigate to the program on the NXT module and press run I get a message saying 'File Error!'.
Any suggestions as to what I may be doing wrong?
Sarah
(8,671 Views)
Accepted by topic author SarahW
It's OK, I found and downloaded the 1.0.1 patch and it works fine now Smiley Happy
(8,668 Views)
This patch 1.0.1, can you please tell me where i can get it? is it a patch for labview or the firmware? btw, my firmware version is 1.03, is that ok? also, my labview version is 8.6
(8,515 Views)
https://lumen.ni.com/nicif/us/evallegotoolkit/content.xhtml
Under the download links.
It says it's a patch for "LabVIEW 8.5 and localized (non-English) versions of LabVIEW", but I'm also using LabVIEW 8.6 and it worked fine. As far as I remember you just have to copy some files to the right place, but the instructions will tell you what to do.
(8,504 Views)
OK, can you do me another favor, can you tell me what firmware version you have? Even the patch doesnt seem to help, with 8.6 and 7.1 versions of labview, and i am not able to figure out why, also, is there a way from within labview where you can change the firmware version?
(8,495 Views)
My firmware version is 1.01. I've never changed it so don't know if you can do it within LabVIEW, sorry!
(8,492 Views)
Oh, that's ok, thanks a lot for the help
(8,490 Views)
