NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
KyleeBot
Error Code 142016
I have a NXT 2.0 and a Dell Inspiron 1545 Laptop running Windows 7.  When I try to connect I get the error code (most of the time) and no connection.  I have read the explanation posted in 2009, but don't know how to find the virtual serial ports mentioned or how to get around the problem.  Until then I am stuck with USB cable.
Does anyone know a solution to this?  Dell points at The NXT driver and Lego points at Dell.
Member
ESearl
Re: Error Code 142016
Open up bluetooth settings from the task bar or control panel and see if you can find and connect to the NXT from there. If that works then you can try and connect within labview again.
If it doesn't work you can buy one of these:
http://shop.lego.com/en-US/Bluetooth-Dongle-9847?p=9847
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
