NI Home
Cart Cart | Help
You are here:
Reply
Member
witwit65
Accepted Solution
xy graph
how can I make XY Graph with LV Web UI builder ?
Member
RamK
Re: xy graph
In the cluster palette, you will find a Bundle Point function.
Use it to create the Point datatype.
Use Build Array to create an array of points.
Wire the array of points to the graph terminal.
Ram Kudukoli.
Active Participant
jareds
Re: xy graph
[ Edited ]
[EDIT: Looks like I was beat to the punch...]
Hi witwit65,
To create an XY Graph in LV Web UI Builder you will use a normal Graph from the palette.  To create the XY data use the Bundle Point function in the Cluster palette to wire in your X and Y data for each point.  Then build an array from those points.  When wired to a graph, the graph will become an XY Graph.  It will look like this:
Jared S.
Applications Engineering
Member
witwit65
Re: xy graph
Thank you very much !
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
