10-02-2013 06:17 AM
dashboard labview is working or samsung galaxys2?thank you po this is my email..mjbaugan@gmail.com
10-03-2013 11:00 AM
Hey if you want more visibility on your issue I recommend creating a new thread and giving more details on that new thread.
10-07-2013 10:01 AM
may i ask if galaxys2 is capable of using the data dash board...we need a display ung boolean....so we need to use this application..thank you
10-07-2013 10:41 AM
The Galaxy S2 phone should be able to run Data Dashboard 1.0. The link to all our app store downloads is here: https://decibel.ni.com/content/docs/DOC-19387
Note that Data Dashboard 1.0 will only show indicators, not controls (so you get read-only access to your data, you can't change the values). But to just display a boolean or other simple data types, it will handle that fine.
11-06-2013 09:54 PM
Hi, can I use data dashoboard to read the ipod's accelerometer and send the values to a VI?
11-07-2013 09:17 AM
Hello geherz,
The LabVIEW Web UI Builder and Data Dashboard board is for questions related to Data Dashboard, not just this thread. You will get more visibility to your question and others will more easily benefit from your question if in the future you start a new thread for each question you have.
Unfortunately, at this time, Data Dashboard Mobile (the version for the iPhone, and which you are probably running on your iPod) does not support sending sensor values to a network shared variable or web service.
Grant M.
Senior Software Engineer | LabVIEW Tablets | National Instruments
12-31-2013 10:04 AM
The Dashboard with shared variables works fine.
Are there more controls (joystick) and indicators (image) planned for the future? Would be nice for robot control in a educational environment.
Regards...
Wijnand
02-25-2014 02:47 AM
good job. Iim studying on it.
07-16-2014 04:23 AM
Actually, WebPager allows any number of controls/indicators and of any look and feel... It also solves many other problems of Data Dashboard.
