LabVIEW Web Development Documents
Example of streaming images over Internet. Single image, java script auto refresh and Motion JPEG.
This example project uses LabVIEW Web Services to publish and stream images over internet.
Project content
  • startup.vi responsible to initialize resources, monitor the Web Service status and close resources if the Web Service be stopped or Stop button pressed.
  • Single_Image.vi is a GET HTTP Method configured as Stream Output Type. It uses the native image/jped HTTP Response MIME Type from LabVIEW Web Services library to publish a single IMAQdx image, previously acquired in Grab mode and flattened as JPEG/Image binary stream. The image can also be resampled.
  • JS_Auto_Refresh.vi is a GET HTTP Method configured as Stream Output Type. It uses the native text/html HTTP Response MIME Type from LabVIEW Web Services library to publish a JavaScript and a html image frame, the image source is the Single_Image method and the JavaScript will refresh the image according to the time gap specified.
Thanks: https://stackoverflow.com/questions/20877813/auto-refresh-images-in-html
  • MJPEG.vi is a GET HTTP Method configured as Stream Output Type and deselected the “Use Headers” to LabVIEW Web Services not include the HTTP Headers, because it uses a non native HTTP MIME Type for stream MJPEG images over HTTP.
Ref1: https://en.wikipedia.org/wiki/Motion_JPEG#M-JPEG_over_HTTP
Ref2: http://www.ietf.org/rfc/rfc2616.txt
OBS: MJPEG over HTTP is not supported by Internet Explorer natively, it is required to install an add-on, at least when I tested it. I didn’t investigate much though.
How to run
1.          Open the project
2.          Right-click on “myWebService” and select “Start”
3.          Right-click in on of methods, e.g. MJPEG.vi and select “Show URL Method…”
4.          Copy this URL in an Internet Browser
Final considerations
Dependencies: NI Vision Acquisition Software
Hardware tested: Laptop with Webcam, cRIO-9068 with Basler USB3.0 camera and sbRIO-9651 + Dev Kit with Basler USB3.0 camera
Comments
Member Ravenink
Member
Hi.
Thank you so much for sharing this. It has been extremelly useful for me, and also really easy to use. It works like a charm.
How difficult would it be to deploy this as a source distribution instead of using it as a LabView project? For my needs, I would need to be able to use the startup.vi outside the project.
Member telles_s
Member
Contributors
