Submissions must be created within the forum section of your local country or region. Copy and paste this template content into a new document in the correct forum section.
Main Contact Email Address : A Student representative YECHAN KIM, ROKSF188@NAVER.COM, +821044452205)
Project Information
Title : Portable Wheelchair Kit for disabled
Description:
Alert in case of accident - Portable kit capable of sending text messages to guardians or 911 in case of emergency such as falling out of wheelchair.
Accident prevention - Detect obstacles by using ultrasonic sensors attached under and rear of the wheelchair and alert the user by making alerting noises or use of LED
Grasp the situation - Gathers datas of the accidents by taking photos to use them for accident inspection
Products :
Labview 2014
App Inventor2
myRIO-1900
Ultrasonic sensor HC-SR04
Bluetooth module RN-42
Cam Microsoft HD-3000
Buzzer ALP1205S
LED Green
The Challenge:
Prevention of death caused by falling out According to Korea Consumer Protection Board, falling out of wheelchair can lead to death by 67%. We tried to prevent people from falling out of wheelchair by using visual and auditory sensors to avoid obstacles and contact the guardians or departments by sending them text messages at the moment of the accident by detecting the fall with the sensors. It is also capable of collecting datas by using camera to capture the moments of the accident to be later used for an accident inpection. It is designed to be a detachable kit so it could be easily applied on wheelchairs already on use to increase marketability. normally it uses bluetooth devices to alert the user and the others visually with LED and auditorily with a buzzer when an obstacle is detected near the bottom and the rear of the wheelchair to prevent accidents.
The Solution:
<Explain the benefits using LabVIEW and NI tools.>
It is easier to operate than other softwares and it ables users to directly program ideas that come to their minds. Also it is easy to check and fix errors and optimize since it shows what is happening on the front panel. With these features, myRIO optimized in labview inspired us to design and create portable kits and we plan on purchase more equipment to create various products.
<Insert image(s) of project with captions.>
<Insert video here.>
<Attach VI code (optional).>
<Level of completion (beta, alpha, or fully functional)>
