LabVIEW Shortcut Menu Plug-Ins
Set Current Event to Value Change.llb
Author: Darren (NI)
Adds a new Set Current Event to Value Change pull-right on a control terminal inside an Event Structure:
This plugin is similar to Create Event, but is useful when there is already an existing frame in the Event Structure that you want to configure for a Value Change event on an existing control.
Attachement is saved in LabVIEW 2016. I would have posted a 2015 version, but the scripting code crashes in 2015. It works fine in 2016, though. For install instructions, go here.
Comments
nik35324
Member
Member
on
Hallo Darren,
Surprisingly when using "Set Current Event to Value Change"  on a Type-Def inside an Event Structure no "Event Source" is selected in "Edit Events Dialog Box", even though the event selector label specifies the event.
Darren
Proven Zealot
Proven Zealot
on
Thanks for the feedback. I won't be able to investigate this issue for a while, so if you (or anybody else reading this) wants to debug the plugin and report your findings back here that would be great.
Contributors
