LabVIEW Real-Time Idea Exchange
About LabVIEW Real-Time Idea Exchange
Have a LabVIEW Real-Time Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW Real-Time Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW Real-Time Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW Real-Time!
Simulate cRIO chassis for development away from the chassis
Right now, you can simulate the I/O from an FPGA target. Timing features and other hardware-specific VIs are not executed, but the code still functions and allows you to debug certain aspects of it without working through the compile process. It would be similarly helpful if you could simulate the real-time controller, or a cRIO in scan mode, with simulated IO. Again, the resultant VI will not be truly realtime, but it would allow useful development without having constant access to the cRIO.
10 Comments
Active Participant smithd
Ooops, I somehow managed to put this in the wrong idea exchange. Smiley Indifferent
Active Participant gsussman
That could dovetail into this idea.
Virtual Machine to Run LVRT
Definitely true, but this seemed like it would be easier for the developers, since they (presumably) have some sort of system in place for the FPGA code.
Knight of NI Knight of NI
Knight of NI
Doesn't matter... This is a great and long awaited feature..
Kudos!
Active Participant Caseyw
We have done some exploration of this idea, and are interested in learning more about customer requirements.
- Would everyone need access to shared variables and other network communication from the simulated environment?
- Would everyone need to integrate compiled libraries (necessitating that we run the LabVIEW Real-Time OS under the hood)
- Would everyone be interested in simulating an entire target, or just choosing to run a VI in a LabVIEW project in "simulation mode" (this is similar to LabVIEW FPGA simulation).
Please post your thoughts.
Best Regards,
Casey Weltzin
Product Manager, LabVIEW Real-Time
Knight of NI
YES on all three
Definitely simulate the entire target.
Member maxwellb
Any news on this? I would love it!
Member Sara_J
The idea was first proposed in 2011.  A query from 2013 as to the status got no apparent response.  Now it's 2014...  I'm hoping someone is still monitoring this thread.  Has this functionality been developed yet?  I need to do some development, but cannot interfere with the production environment and do not have the extra hardware to set up a full test environment.  A cRIO chassis simulator would really, really help right now.
Member Annapoorani
Any updates on adding "Simulate cRIO chassis".. It will be very helpful!
Member Ajayvignesh_MV
Any update on this feature.. I'm looking for this kind of simulation.
