LabVIEW Real-Time Idea Exchange
About LabVIEW Real-Time Idea Exchange
Have a LabVIEW Real-Time Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW Real-Time Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW Real-Time Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW Real-Time!
Scan Engine: FailSafe value for output nodes
I noticed there seem to be no way to guarantee the state of an output module controlled by a scan engine in case the RT Application (or the Host Application, depending who is controlling the chassis) crashs. With FPGA one can program some kind of watchdog setting back the output values of a module in case the RT Exe fails. With Scan there just seem to be no possibility.
This is why I think adding a FailSafe Value for a Scan I/O node could be a creat idea. in ase the RT application got aborted  or stops  without cleanup, the output value would not be random no more but set back to their FailSafe value. I imagine it could look like that:
What do you think about it?
______________
Florian Abry
Application Engineer Group Leader, NI Germany
5 Comments
That would be a useful function. :-)
That would be very nice. :-)
This could also be useful for more distributed systems (like ethercat for example). If I am not mistaken, the only way to get ethercat devices (9144) or the equivalent ethernet chassis (9148) into a safe state upon connection loss is to write custom FPGA code. It would be pretty cool if this were a core feature of the scan engine for systems like that.
9144 has a built in watchdog and safe stating of outputs.
Stephen B
True story (kb here for anyone interested: http://digital.ni.com/public.nsf/allkb/745AE05D7A791A9886257750006B480C?OpenDocument).
What I was looking for but failed to actually say was that I wanted to have a configurable failsafe as shown in the picture. But I failed to use my words Smiley Sad
